Help with MKS Robin NANO v1.2
Printer Model: Fokoos Odin 5 F3
MCU / Printerboard: MKS Robin Nano V1.2
I was running klipper fine on this board but changed back to Marlin to get BL touch because I couldn’t get it to work with Klipper. Long story short I figured out the BL touch issue and reflash to klipper. Afgter reflashing I printed a few file and everything went fine. I turned off the printer, Cam back next day powered it back on and the touch screen went white. At first I thought it was the cable. They I thought it maybe a klipper issue so I tried to flash back to Marlin but this time it will not update the flash. I did notice that I left the SD card in when I restarted it. Maybe it tried to reflash klipper again?
THe odd thing is that Klipper will still connect, but when I try to home the only thing that happens is that the x axis moves down about 10 mm, nothing else.
Thinking that it may have screwed up the flash and bootloader I bought an ST-link V2 in an attempt to reflash bootloader, but no matter what I do, I cannot get the stling untility or the vube programmer to connect to target.
Any suggestions on what to try next?
Thanks
Brian.
Hello @rb8720 !
Attaching the klippy.log to your next post.
Here is the latest klippy log
klippy.log (70.1 KB)
