Home offset for small PEI
Hello,
My brand new PEI sheet has just arrived. Unfortunately this is too small, and 3-3 mms on every edge of the sheet if I place it in the very center.
I’d like to use this sheet while the replacement not arrive. Is there any way to modify the printer.cfg to set these offsets?
Thanks a lot!
Just determine the toolhead coordinates where your PEI sheet actually starts, define this as 0,0 and use the size of the PEI as build-size in the slicer.
Thanks a lot . Can you help me, how can I start it? I’ve tried to set the position_min and position_endstop settings to the correct negative values without any good result. In case of G28 gcode it always goes to x0 y0 z0 position.
See this graphic (by courtesy of Voron)
You would set:
position_endstop: 255
position_max: 255
This allows your printer to reach your desired X=0 and Y=0.
In your slicer’s configuration you would set a bedsize of only 250 x 250 making sure that your print actually ends up on the bed.
In your case X=0 and Y=0 is the start of your PEI and the size of your PEI is the bedsize for the slicer.
Thanks, it’s solved. I don’t know how can I set the topic to closed :frowning:
