I have a couple of different build surfaces I use, and they require different Z offsets. On one side of my flex plate I have a textured PEI surface, and on the other a smooth PEI sheet. I found setting and storing the Z offset to be really tedious. Fortunately I was able to use the menu system to build a system for choosing a build surface from a preconfigured list, save the Z offset during live tuning, and apply the offset automatically at the start of a print. I’m using the save_variables config option; modification to these variables via the SAVE_VARIABLE command are applied immediately and accessible when referencing the printer.save_variables.variables dict.
Changing the bed surface and applying its stored Z offset is as simple as going to the Setup menu on your attached display and choosing from the Bed: list.
setup
printer.cfg
[save_variables]
filename: ~/klipper_config/saved_vars.cfg
saved_vars.cfg
Populate bed_surfaces with a list of your print surfaces. These need to be variables, not friendly names; if you’ve got multiple smooth surfaces, name them something like smooth_01 and smooth_02. Note the format: the value needs to be an eval-able Python string that returns a list of strings.
Set the selected_bed_surface key to one of the entries in the bed_surfaces list, and note the quotes around the value.
For each item in the bed_surfaces list, create a saved variable prefixed with bed_surface_offsets.: these will store the per-surface offset values.
Below is a slightly-formatted version of my current vars file:
[Variables]
bed_surfaces = ['smooth', 'textured']
selected_bed_surface = 'smooth'
bed_surface_offsets.smooth = -0.185
bed_surface_offsets.textured = -0.17
menus
;; choose a bed surface from a pre-configured list
[menu __main __setup __bed_surface]
type: input
name: Bed: { printer.save_variables.variables.bed_surfaces[menu.input | int] }
input: { printer.save_variables.variables.bed_surfaces.index(printer.save_variables.variables.selected_bed_surface) | float }
input_min: 0.0
input_max: { ((printer.save_variables.variables.bed_surfaces | length) - 1) | float }
input_step: 1.0
SAVE_VARIABLE VARIABLE=selected_bed_surface VALUE="'{ printer.save_variables.variables.bed_surfaces[menu.input | int] }'"
;; tunes the Z offset from the setup menu, saves the offset
;; can be performed while not actively printing
[menu __main __setup __offsetz]
type: input
name: Offset Z:{ '%05.3f' % menu.input }
input: { printer.save_variables.variables["bed_surface_offsets." + printer.save_variables.variables.selected_bed_surface] | float }
input_min: -5
input_max: 5
input_step: 0.005
realtime: True
RESPOND TYPE=command MSG="{ 'bed surface: %s, offset: %r' % (printer.save_variables.variables.selected_bed_surface, menu.input) }"
SET_GCODE_OFFSET Z={ '%.3f' % menu.input } MOVE={ 1 if printer.toolhead.homed_axes == 'XYZ' else 0 }
SAVE_VARIABLE VARIABLE=bed_surface_offsets.{ printer.save_variables.variables.selected_bed_surface } VALUE={ '%.3f' % menu.input }
;; tunes the Z offset from the tune menu, saves the offset
[menu __main __tune __offsetz]
type: input
input: { printer.gcode_move.homing_origin.z }
input_min: -5
input_max: 5
input_step: 0.005
realtime: True
SET_GCODE_OFFSET Z={ '%.3f' % menu.input } MOVE=1
PRINT_START gcode
{% set svv = printer.save_variables.variables %}
;; apply Z offset for configured bed surface
RESPOND TYPE=command MSG="{ 'bed surface: %s, offset: %r' % (svv.selected_bed_surface, svv['bed_surface_offsets.' + svv.selected_bed_surface]) }"
SET_GCODE_OFFSET MOVE=1 Z={ '%.3f' % (svv["bed_surface_offsets." + svv.selected_bed_surface] | float) }
