Feature Request > Z-OFFSET updater
When we click this button:,
Screenshot 2024-01-16 115434
Can we make it update this figure:,
Screenshot 2024-01-16 115519
Instead of having to manually update it?
Thanks
You know about
https://www.klipper3d.org/G-Codes.html#z_offset_apply_endstop
and
https://www.klipper3d.org/G-Codes.html#z_offset_apply_probe
Make a macro with the one of your use plus a SAVE_CONFIG and put it onto your frontend
Neither of those work when the z_offsets are automatically commented out by klipper.
Screenshot 2024-01-16 184914
The factor in my OP needs to be updated instead.
Thanks though.
The actual values appear at the end of the printer.cfg in the SAVE_CONFIG section
#*# [extruder]
#*# control = pid
#*# pid_kp = 19.730
#*# pid_ki = 0.788
#*# pid_kd = 123.560
#*# [bltouch]
#*# z_offset = 1.740
