Hotend Shutdown
Printer Model:
MCU / Printerboard:
ok i have upgraded my cr10 pro max with a skr 3e v3 and have used the ribbon cable to connect the board as i did not want to have wires everywere. Now i can heat the bed no problems the temps are on the web ui but when i goto heat hot end i get a shutdown error please can some one help as the board im using i took off a cr10 pro v2 that was already converted i have checked the pa0 is the pin but just unusual i have attached my klipper log thanks in advance
klippy.log (138.0 KB)
Hello @cdcrossy !
Have you checked for short circuits on the wires to the hotend?
yes im going to directly put a new cartrige in see if that works ill keep you updated
