How do I request a config file for the CR-M4? (stock and Octopus Max EZ)
Printer Model: CR-M4
MCU / Printerboard: Only one version specific to the CR-M4 Atmega AVR atmega 2560
Host / SBC Sonic Pad (suspect subpar usb ports I’m having random disconnects) Also using a pc to run klipper which is why I’m requesting a config file. I recently used KIAUH on an unused pc but there is not a file in klipper/config that I can find to move forward with “make” I have some config info from config file created by the sonic pad and accessed via web interface (orca slicer) Suspect that file is Sonic pad specific.
klippy (2).log (3.7 KB)
I would like to eventually replace the stock control board (ordered a Octopus Max EZ) and move to using larger nozzle sizes. It has a very large build volume. But I’m still new to this and feel like I should learn to walk before I run. Although I would really like to get away from a Crealtiy version of Klipper and the use the real thing. And spending hours over what might be a poor usb port is … The goal is printing large and reliably.
Thanks for any help.
Maybe this will help: Creality_Sonic_Pad/printer_configrations/printer-CrM4-401.cfg at main · CrealityOfficial/Creality_Sonic_Pad · GitHub
Refer to the comment here: Change KAMP Temperature for Mesh probing - #20 by Sineos
You should be aware that it is entirely possible that switching out the board on this printer is far from being as straight forward as you might wish for (even might be impossible without investing significant development work)
