I see issues with some matte or silk PLAs with bed adhesion but only for the first mm or so, after that they lay perfectly smooth and flat – zero adhesion problems after that. So I’m wondering if there is a way to get more ‘squish’ and/or spit out more filament only for 1 to 2 mm for each new start, only on Layer 1?
All major slicers that I’m aware of, have a z-offset configuration.
As an alternative, you can pass a z-offset, e.g. within your START_PRINT macro and have it processed by Klipper via SET_GCODE_OFFSET Z={Z_OFFSET} or something similar.
