Printer Model: All Klipper Based
MCU / Printerboard: cross board
I am running a BTT smart filament sensor that gives me false positives for TPU and I currently want to just disable it if printing TPU.
However - in my slicer (orca) I always turn the sensor off for eg. the 1st layer of the print and then on again after the 1st layer.
Now I would like to modify these macros, so that the sensor gets enabled if it was enabled when the print starts - and stays disabled if it initially was disabled.
I found SET_FILAMENT_SENSOR SENSOR=filament_sensor ENABLE={1/0} but no GET_FILAMENT_SENSOR SENSOR=filament_sensor to save it in a variable or so to later use this to SET it as described.
Is there a way to do this?
Thanks!
BJ
