How to use z_thermal_adjust to compensate hotend expansion?
Printer Model: Voron 2.4
MCU / Printerboard: SpiderV2.3
Host / SBC: RPI4B
klippy (3).log (68.4 KB)
I found out that I need to adjust SET_GCODE_OFFSET Z_ADJUST=+0.075 every time I’m printing at 275°C instead of 215°C to get a perfect first layer.
I tried configuring temp_coeff to negative and hardcoding ref_temp to be 215, but I got stuck when it told me I could not use the same temperature sensor twice. I guess it’s designed to compensate for frame expansion, not hotend expansion. But still, I need a way to compensate my hotend expansion.
Sorry, where is this gone?
Added, didn’t think it was relevant, sorry for that
As far as I know, there is no built in possibility.
FWIW, you could probably write a macro that calculates the needed compensation and call it via PRINT_START or similar.
Is it possible to duplicate one sensor to use as if there are two virtual sensors?
Not sure what you are trying to achieve.
You can get the extruder’s target temperature in a macro and from this target temperature calculate your needed offset. Then pass the offset to SET_GCODE_OFFSET
It’s because I’m really not familiar with the coding language used for macros, and I want to see if it’s possible to work around the limitation of [z_thermal_adjust], which is that it can only be used with a brand new, unused sensor.
