Inverting extruder_stepper dir_pin from gcode macro
Looking for a way to invert extruder_stepper dir_pin from gcode command… currently I am making macros to sync extruder stepper to the extruder, extruder_stepper direction is tool dependent (T0&T1 in the same direction as the extruder, rest is in the opposite direction) then use SYNC_EXTRUDER_MOTION command to start the print with SYNC enabled
See G-Codes - Klipper documentation
Thank you…but I wanted to use Belay which changes the rotation distance to keep the 2 motors in sync, thus I am looking for another way
I cannot comment on 3rd party Klipper modifications
