Issue with C920 logitech on btt M8P+CB1 combo
Printer Model: modded ender 3 pro
MCU / Printerboard: M8P V2
Host / SBC : CB1
Hi, I have had M8P v1.2 with CB1 combo on my modded ender 5 pro. configuring logitech C920 on crowsnest was a breeze.
Bought another M8P v2.0 with CB1 combo and can’t even get the camera working (bought same camera for this).
I tried changing from /dev/video0 to the actual path on v4l/by-id in crowsnest.
tried changing the mode from ustreamer to mjpg
tried lowering down resolution and fps
and when it’s working, it only give between 1 to 5 fps. then camera normally stops working again after reboot.
I’m not sure if this has something to do with the debian version installed on Cb1 as I only recently got it and installed the latest one from their website.
any help would be much appreciated.
if klippy log is helpful please let me know and I will get it as I’m not in front of my laptop. just wanted to get this out before I forget. thanks
I’ll check my config again for you, but I do remember oddly a couple times I had to completely power down the board then fire it back up for the camera to get recognized. But I’ll check my config later tonight and get back to you
thanks. I’m still scratching my head. Not that it really matters, I also checked the SD card on my manta m8p v1.2 and I’m using samsung evo plus 32GB, and on my m8p v2, I’ve got sandisk extreme pro 64GB, which I think it’s probably faster than samsung evo plus. I thought SD card was the bottleneck but seems like even a much slower SD card will be okay as it doesn’t really demand speed like a camera does.
