Cube pro conversion
SKR Mini 3 V3
Rasperry Pi 4 Model B
Fluidd
Hi All
Recently started a conversion of a Cube Pro to run on Klipper. All going well until I got to the hotend. I’m using a creality K1 Hotend purchased from Amazon. In the fluidd console the temperature readings are 520c at room temperature. I have been unable to find the correct sensor type to put in the “sensor_type” field so am assuming this is causing the issue.
I would really appreciate any help with the sensor type I should be using for this thermistor. Please see the link below.
LOL, I know. I was referring to the fact that @carptench2014 answered to you posting his log and again answering to @EddyMI3D with the same log. I only wanted to make sure you do not accidentally mix logs
