Printer Model: k1 Max
MCU / Printerboard: Manta m8p 2.0
Host / SBC: CM4 w/32gb emmc
klippy.log (95.7 KB)
Hi all,
I’m working on upgrading my Creality K1 Max with a Manta M8P mainboard, and I’m stuck with the toolhead MCU. I can successfully flash firmware to the toolhead using mcu_util.py, but the bootloader never starts Klipper afterwards.
Hardware details
Printer: Creality K1 Max
Toolhead board: NOZZLE-C-V13 (GD32F303CBT6)
Flashing via: USB → RS232 adapter
Mainboard: Manta M8P (STM32H723)
Host: CM4 running Mainsail OS
What works
Flashing with
mcu_util.pysucceeds every time. Example log:Firmware updated successfully send app_start request send app_start request send app_start request App start failed after 3 retries -
Bootloader handshakes, accepts firmware, and reports flash completed.
What fails
The MCU never responds after reboot.
Klipper log shows:
mcu 'toolhead': Timeout on connect mcu 'toolhead': Serial connection closed -
Full power cycles don’t help.
I tried building firmware with:
STM32F103processor -
Serial (USART1, PA9/PA10), 250000 baud
Clock: 8 MHz (also tested 12 MHz)
Bootloader offset: 8 KiB and 16 KiB
All combinations flash cleanly but still fail
app_start.
What I’m asking
Has anyone successfully built Klipper for the K1/K1 Max NOZZLE-C-V13 (GD32F303CBT6) toolhead?
Which menuconfig settings (offset, crystal, etc.) are confirmed working?
Could this board require something non-standard (different offset, USB vs UART build, etc.)?
- Full
klippy.logattached.
Thanks in advance for any guidance!…
