K1C Error {"code": "key294", "msg": "Timeout on wait for '2' response", "values":["tmcuart_response"]}
Printer Model: Creality K1C
MCU / Printerboard: Stock Config
Now 2 time in a row midprint I get the error {“code”: “key294”, “msg”: “Timeout on wait for ‘2’ response”, “values”:[“tmcuart_response”]} and the Printer freezes.
Rooted with Creality Helper Script, got Guppy Sceen, OctoEverywhere, OctoApp Companion and Mainsail installed.
Printer worked flawless up to the last 24 hours.
Thank you
EDIT: First error was {“code”:“key560”,“msg”:“Lost communication with MCU ‘mcu’”}
klippy.zip (1.2 MB)
Hello @Komger !
I don’t know what you are running there, but that is definitely no genuine Klipper.
I just used the Creality Helper Script but it just mentioned that its dirty and performed an update.
Maybe now its working again…
Shouldn’t the K1C run a standard Klipper configuration when rooted?
For this is Cre@lity, it is everything but genuine or standard
@Komger
The K1s run on Creality OS and a custom Creality-altered Klipper, so the error codes will not be understood by the true Klipper users.
Help will not be found here but only via Creality and K1 users.
Please try searching with Goolge for Creality K1 error codes.
