KAMP not working on Delta
Printer Model: Self built delta (loosely based on a Kossel)
MCU / Printerboard: MKS SBase Gen1.3
klippy.log - yes
klippy.log.zip (52.6 KB)
Hi all,
I’m having trouble getting KAMP to work with my delta.
I’ve followed the instructions and got all configs in place (as far as I can see) but when I try and print I get the following error
Error evaluating ‘gcode_macro BED_MESH_CALIBRATE:gcode’: jinja2.exceptions.UndefinedError: ‘dict object’ has no attribute ‘probe_count’
I think its cause a delta probe config is ‘round_probe_count’ and not ‘probe_count’ but I don’t know how to fix it. Or it could be something else all together.
Hello @Mils24 !
You added GitHub - kyleisah/Klipper-Adaptive-Meshing-Purging: A unique leveling solution for Klipper-enabled 3D printers! to your Klipper setup?
Adaptive Mesh is already included in Klipper:
https://www.klipper3d.org/Bed_Mesh.html#adaptive-meshes
Hi @EddyMI3D, yes I did.
They may interfere with each other.
Can someone please explain to me how to uninstall KAMP? or should I just wipe the SD card and do a fresh install of Klipper?
