Kamp Purge Line overlaps object
Printer Model: Creality K1C
MCU / Printerboard: stock
Host / SBC stock
I installed KAMP awhile ago and it seemed to work well for most projects but I tried to print 2 lithophanes that are further apart so they I can do them one at a time, The issue is the purge line is within the first object, it might be in the support material but its still causing issues. I don’t know what to do to figure out why its happening, my “hack” to fix it is quick pause after the purge line peal it off and let it continue printing.
I know I successfully printed them previously but I don’t know if it was before or after I installed KAMP.
Please let me know if any other settings or files would be helpful to figure out what’s going on.
klippy.log (2.1 MB)
Hi @charely6 ,
The K1 series of printers doesn’t run legit Klipper, so the help we can give will be limited.
yeah I know its not exactly the same, I did the the guide from here Wiki for Creality Helper Script to “unlock” it and get fluidd and Kamp and some other stuff installed.
this is a slicer issue, stuff like support material and brims are not reported in the EXCLUDE_OBJECT command to klipper. Kamp uses these coordinates to calculate the edge of the mesh, which then overlaps with these things.
a workaround is to add a margin to your adaptive mesh.
and complain to the slicer team for a fix.
