Klipper got a mind of its own?
Printer Model: Anycubic Kobra 2 Neo
Host / SBC: Trigorilla Pro B V1.02/Raspberry Pi Zero 2 (MainsailOS, no webcam)
klippy.log: klippy(1).log (2.0 MB)
So I decided to try klipper. Cool, it worked. But when i print something with a hole on the bottom or pretty much anything except the xyz cube, it does this weird thing that looks like a purge line. It never does any inside walls on that object either. Ive messed with 3 slicers (orca, prusa, cura) and spent awhile tweaking my start gcode and many other things but nothing seems to fix this. It shows the file right in the slicer preview, and even on the live gcode view on mainsail but does not print it right. I’m a new user in this community since I only got klipper yesterday so I can only imbed one item. I will comment the other stuff.
Fail:
another weird thing… it keeps cutting corners and for the most part looking terrible. I used the printer.cfg that everyone on the internet uses for this printer.
I found a different printer.cfg which seems to be working better.
