Keep getting "Unable to open file"
Printer Model: Ender 3
MCU / Printerboard: /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0/ V4.2.2
Host / SBC Raspberry Pi Zero 2W
I had Klipper/ Mainsail/ Moonraker installed, then i bought another Ender 3. I tried to hook them up together, and everything crashed so I had to restart. After a few headaches and annoyances later, I decided to make each printer have an individual Pi for each.
Reconnected everything for Printer A, got Mainsail with Klipper up and running, went to do a test print and received “Unable to open file”. Changed Virtual sd card paths on both Mainsail cfg and Printer cfg to match, no luck.
I dont know what to do from here. If im missing information, let me know and ill get it as soon as i can find it.
Klippy Log:
klippy (1).log (213.8 KB)
Let me know if the link doesnt work, ill paste the entire log if necessary.
Welcome Stego_saurus,
use the search function here. I’m quite sure your problem was discussed before. E.g. Unable to open file with new printer setup
Good luck, hcet14
