Hi folks, I have an AON3D M2+ running Klipper, and it uses a vacuum chuck to hold build sheets on the bed, in a heated chamber so messing with stuff in there is pretty annoying.
I’m trying to use initial_pins
in menuconfig and the value
/ shutdown_value
parameters on the [output_pin]
config block to keep the pump on throughout restarts so I don’t have to fiddle with it again every time I eg save my config. I’ve got it so it comes back on after a restart, but there’s a brief blip of low state on the pin which is enough to kill my vacuum.
Is this just a limitation of the processor, or am I missing a config setting someplace? It’s an atmega2560 board, specifically a Controllino Mega which is a glorified Arduino with some relays on it.
The config block is
[output_pin vacuum_bed]
pin: PL0
pwm: false
value: 1
shutdown_value: 1
And the initial_pins field in menuconfig is just PL0
Thanks!
-Nick
