Kipper error k1 max
Printer Model: Creality K1 Max
MCU / Printerboard: creality
printer.zip (3.9 KB)
klippy.zip (7.5 MB)
Describe your issues
I’m currently run in to a problem with the error
{“code”: “key341”, “msg”: “Section ‘gcoce_macro adapt_purge_mod’ is not a valid config section\n\nOnce the underlying issue is corrected, use the \“RESTART\”\ncommand to reload the config and restart the host software.\nPrinter is halted\n”, “values”: [“gcoce_macro adapt_purge_mod”]}
I see that the 'gcoce_macro adapt_purge_mod is miss spelled and I’m not sure how to fix it
Hello @mrplasma !
I don’t know that we can help you: 3D Printers with Preinstalled and Modified Klipper Versions
Ok…….. I have fix the current issue with the misspelling I found somebody that came across the same issue and fixed it we re-uploaded a different kamp file to fix it.
But now I’m running into a new issue where clippers not connecting to Moonraker and I’ve tried to uninstall and reinstall both and it still having problems
Hi @mrplasma ,
The K1 series runs a heavily modified “Klipper” version, so we can’t help much. Please reach out to Creality support for this issue.
