No variables.cfg K1 Max
Printer Model: K1 Max
klippy (2).log (849.4 KB)
MCU / Printerboard:
I have been installing Klipper to my K1 Max by following Creality K1 K1 Max root access Use Prusa slicer, Klipper, Fluidd, Moonraker like a normal 3D printer. It worked perfectly. Then I cloned jschuh’s Klipper-macros and now ik get this message:
Internal error during connect: [Errno 2] No such file or directory: ‘/root/usr/data/printer_data/config/klipper-macros/variables.cfg’
Printer is halted
Now I found a similar post of MangoTea where LifeOfBrian mentioned that the path in the slot.cfg (macros.cfg for me) and skippy.log should be the same.
In my opinion these paths are the same and still I get this message. What I’m failing to see?
**edited: I’ve changed to different folders multiple times, but no difference.
Hello @Pilgrim771202223 !
Rooted or not - it’s still crappy Creality’s crappy version of Klipper:
Git version: '09faed31-dirty
Probably you are not familiar with UNIX.
[save_variables]
filename = root/usr/data/printer_data/klipper-macros/tempvar.cfg
So, probably you want:
/root/usr/data/printer_data/klipper-macros/tempvar.cfg
There should be always a leading slash.
