Ive found that their something wrong with the BigTreeTech tft35 spi display. their must be a shot in the digitizer triggering the prints. when I unplug the display I never have a problem. but as soon as its connected it started doing it again
any news or confirmation on this issue? i have btt tft35spi screen and unexpected restarts of the last print…
do i have to disconnect the spi to the screen or can i just disable the overlay to test?
Hello!
I have the same Problems here. Setup: BTT Manta M5P + CB1 + TFT35 Display - Mainsail, Klipper.
I think it occurs after every Print when the Printer is unattended, but most time i am there when the Print finishes and going back to the Mainscreen on the TFT35.
Has anyone found a solution or Workaround?
Is it possible automatically to go to the Mainscreen after Print? I can live without th"Restart Print"-Button…
Seems good!
Added only
#~# [main]
#~# job_complete_timeout: 5
The Display goes 5 Seconds after printing to the Main-Screen and i have no more Restarts!
Nice Workaround, thank you very much!
if that solved your problem that’s great, just one thing if you change a parameter in the screen like the theme or other you will have to reset the line. And I also noticed that sometimes the screen does not stay on the page with the information of the current print but switches to the page where we can adjust the parameters during the print, which is also the same location as the re-print button, in this case you have to exit otherwise you will not return to the home screen.
Yes, i have seen this behaviour on my printer too.
Here is another Example with BTT-Manta and BTT-tft35 where that Area is triggered by “Ghost-Hands”:
@Colase3D Do you also have this Board/Screen combination?
no i have printerboard: creality 4.2.7, Btt-pi 1.2, display tft35 spi
