Klipper installation via KIUAH (and .sh script)
Printer Model: Ender 3
MCU / Printerboard: SKR mini e3 v2.0
Host / SBC: Raspberry pi 3B+
klippy.log nan
I have a fresh Raspi Lite OS install on my raspberry pi and I am following the instructions here
Encountered the following error
Unpacking virtualenv (20.31.2+ds-1) …
Errors were encountered while processing:
/tmp/apt-dpkg-install-Dkr0pl/25-libstdc+±arm-none-eabi-newlib_15%3a14.2.rel1-1+29_all.deb
[ERROR] Error installing packages:
E: Sub-process /usr/bin/dpkg returned an error code (1)
[ERROR] Error during installation of Klipper requirements!
[ERROR] Command ‘[‘sudo’, ‘apt-get’, ‘install’, ‘-y’, ‘libusb-1.0’, ‘python3-dev’, ‘libffi-dev’, ‘gcc-arm-none-eabi’, ‘gcc-avr’, ‘virtualenv’, ‘libnewlib-arm-none-eabi’, ‘binutils-arm-none-eabi’, ‘avrdude’, ‘binutils-avr’, ‘python3-virtualenv’, ‘libusb-dev’, ‘libncurses-dev’, ‘avr-libc’, ‘stm32flash’, ‘dfu-util’]’ returned non-zero exit status 100.
[ERROR] Klipper installation failed!
This is not what I expect when I follow a tutorial. Also, I tried installing klipper on a fresh octopi OS image with the .sh script, but that also failed because of a python-dev library that was missing.
If anyone can point me in the right direction for the KIUAH installation that would be great. At the moment I cannot find any kiuah or klipper logs, the logs for dpkg do not show anything useful.
If you want more logs or info please ask
Weirdly enough, afterwards I did a sudo apt-get install -f (to fix broken packages). Then startd up KIAUH again. It mentioned that I had an incomplete Klipper installation.
I followed the install menu again and now everything went fine.
