Peurif
April 3, 2022, 6:53am
1
this morning i have try print a gcode, generated from CURA (last version) and in the first layer, the print stopped with these message in console:
Internal error on command:“G1”
Attach Klipper log
Some ideas can be?
Klipper error G1.log (726.6 KB)
Peurif
April 3, 2022, 7:00am
2
i have read some about… i have configured the extruder driver, with these lines
[tmc2209 extruder]
interpolate: true
uart_pin: e_uart_pin
run_current: 0.901
hold_current: 0.1
stealthchop_threshold: 0
driver_TBL: 1
driver_HEND: 6
driver_HSTRT: 7
driver_TOFF: 4
Sineos
April 3, 2022, 9:33am
3
This is not the cause, it is a symptom. If you take a look at your log, you will find some lines above:
TMC 'extruder' reports GSTAT: 00000001 reset=1(Reset)
Transition to shutdown state: TMC 'extruder' reports error: GSTAT: 00000001 reset=1(Reset)
Dumping gcode input 0 blocks
Dumping 20 requests for client 1968865032
See: TMC 'extruder' reports error: GSTAT: 00000001 reset=1(reset - #39 by Sineos
These values depend on the exact driver type and the specification of the exact stepper model. They should be determined carefully by referring to the TMC driver spec, knowing your stepper and doing quite some experiments (even down to measurements with an Oscilloscope).
Copying them from somewhere in the WWW is not the way to go.
neilmc
October 21, 2023, 1:33am
4
‘Use an Oscilliscope to figure out the software’
I ran into this today after update. Immediately after the test extrude my printer MCU crashes with the same error.
Hello @neilmc !
You noticed this:
Things have changes since then. Please open a new thread in General Discussion with all requested information.
