Klipper 'mcu' shutdown: timer too close
Printer Model: Tevo Tornado
MCU / Printerboard: MKS Gen L V1.0 (ATMEGA2560) w TMC2208 (UART)
klippy.zip (3.2 MB)
Klippy Version: klipper v0.11.0-299-gb1f597c5
Host: Raspberry Pi Zero 2 W Rev 1.0
fluid version: fluidd v1.25.3
printer.cfg (11.1 KB)
Slicer: CuraEngine builtin Cura 5.4
Hi, I get a random mcu shutdown due to timer too close. I changed the position of the model in Cura and did a second try, but with the same outcome at around the same print area. Second time some layers later. Before the second print I also tightened all cables.
While analyzing the klippy.log I am seeing a spike of Bandwith and Host buffer around the shutdown. Never had problems before, but it seems that this is the biggest and most complicated .gcode file I printed yet (141 MB).
Can there be issues from the slicer? Do you have any ideas how to fix this problem? I read something about increasing the buffer size, but this would flatten some fluctuating data amount, here I see more of a big spike, which leads to the problem and the timer getting violated.
Cheers
Denis
UPDATE/SOLUTION: The problem occurred more frequently, even after disabling nearly everything on the host (webcam, etc) and reducing the complexity. A fresh install on a new SD card solved the problems and the print succeeded with the previous high complexity and even time-lapse active. Most likely it was a faulty/well-aged SD card.
Thanks for the support Arakon, @LifeOfBrian and @Sineos
Here is the log of the second attempt, basically the same crash:
klippy_second_attempt.zip (3.0 MB)
If the slicing resolution is set too high, that can cause high load during prints with lots of direction changes. Maybe check what that is set to in cura.
Yes there are a lot of direction changes in that printing area. Maximum Resolution is 0.5mm and Maximum Deviation is 0.025mm. Increasing the maximum deviation to e.g. 0.05mm would make it slightly less accurate, but reduces a lot direction changes. Will try that, thank you.
So, if it would help, this means the mcu (ATMEGA2560) is on the limit to process the amount of commands in time, right?
Check this for better understanding:
As indicated by @LifeOfBrian this is rather a host problem and not a board problem.
Usually, this type of error is not caused by too high resolution unless the amount of data is somehow overpowering the host.
UPDATE/SOLUTION:
