Klipper v0.13.0 Release!
The v0.13.0 version of Klipper has now been released! For more information on the release, please see:
https://www.klipper3d.org/Releases.html
New in this release:
  • New “sweeping vibrations” resonance testing mechanism for input shaper.
  • Fans and GPIO pins can now be assigned a formula (via Jinja2 “templates”).
  • The bed_mesh code now supports “adaptive bed mesh”. The area probed can be adjusted for the size of the print.
  • A new minimum_cruise_ratio kinematic parameter has been added (it replaces the previous max_accel_to_decel parameter).
  • Several new sensors added:
    • Support for ldc1612 “eddy” current sensors. This includes probing support, fast “scan” probing, and temperature calibration.
    • New support for “load cell” measurements. Support for connecting these load cells to hx71x and ads1220 ADC sensors.
    • Support for BMP180, BMP388, and SHT3x temperature sensors. Support for measuring temperature with ADS1x1x ADC chips.
    • New lis3dh and icm20948 accelerometer support.
    • Support for mt6816 and mt6826s “hall angle” sensors.
  • New micro-controller improvements:
    • New support for rp2350 micro-controllers.
    • Existing rp2040 chips now run at 200MHz (up from 125Mhz).
    • The micro-controller code can now define many more commands (up to 16384 from 128).
  • Other modules added: aip31068_spi, canbus_stats, error_mcu, garbage_collection, pwm_cycle_time, pwm_tool, garbage_collection.
  • Several bug fixes and code cleanups.
For further information on Klipper, please see:
