Klipper won’t connect to my Creality 4.2.2 board — fails with error (-71)
Printer Model: Ender 3 V2
MCU / Printerboard: STFM103 - V4.2.2
Host / SBC - x86 based mini-pc with Debian 12 - Klipper + Moonraker + Mainsail
klippy (1).log (43.0 KB)
Hi all,
I’m trying to run Klipper on a Creality 4.2.2 board (Ender 3 V2). The firmware flashes fine, and the CH340 USB‑serial chip shows up in lsusb:
“Bus 001 Device 008: ID 1a86:7523 QinHeng Electronics CH340 serial converter”
But Klipper fails to connect. The log shows: “mcu ‘mcu’: Starting serial connect mcu ‘mcu’: Unable to open serial port: [Errno 5] could not open port /dev/ttyUSB0: Input/output error”
Earlier I also saw: “ch341-uart: probe of ttyUSB0 failed with error -71”
As I said earlier this is a fresh install of Debian Bookworm on an x86 based Mini-PC, I have used KIAUH to install Klipper, Mainsail, Crowsnest, and Moonraker. I would also get the “unable to connect to mcu” error in Mainsail.
Does anyone have any solutions to this? I have attached my log.
Use the utility in KIAUH to find the id of the SERIAL device. USB is the conduit but connection with the MCU is serial.
My guess is your board didn’t actually flash. If that is the case KIAUH won’t find your MCU. Creality 4.2.2 and 4.2.7 boards are notoriously hard to flash.
Google [Creality 4.2.2 klipper] and you’ll get 100’s of hits starting with this:
I first flashed the stock creality firmware and then flashed it with firmware obtained thru ‘make menuconfig’ - and its giving me the same result. There is this repeated “-71” error, how does one fix that?
What did you put into printer.cfg for the MCU ID?
A new klippy.log would help.
klippy.log (27.0 KB)
Mainsail connects to Moonraker now?
If so go the the system tab and click on [DEVICES], highlight serial and hit refresh.
Does /dev/serial/by-id/usb-1a86_USB_Serial-if00-port0 show up?
Yes, its always been showing up, I get the /dev/serial/by-id/ and the /by-path/, I just did a re-install of klipper only thru KIAUH and now this is the screen I get on Mainsail, I have attached a new log.
klippy.log (7.5 KB)
Makes no sense to me… I’d try a different cable. Next I would triple check the settings in makemenu then recompile klippy.bin and reflash.
Don’t forget filename has to be different than the one that flashed the current FW.
Are you 100% sure your board is a V4.2.2 with the STM32F103 chip?
Yes it is, I got the printer to work though, I put tape on the 5v pad on a data cable so it wouldn’t interfere among some other stuff, thanks for helping though!
Please mark your last post as the solution.
Happy printing
