Klippy.log stops logging after aprox 1 min
Printer Model: Custom
MCU / Printerboard: Manta M8P
Host / SBC CB1
klippy (5).log (141.0 KB)
As you can see, some other logs are being updated, while klippy log isnt:
This is happening in a different machine from the one i’m trying to fix the horizon problem. This one is a machine i have only for testing and whatever…
I dunno if the datetime might be a problem here as i have a dns problem and it gets wrong the time. (In the image, time is 15:20, but the real time here is 21:50)
Can be the date time the problem?
Klipper uses the monotonic timer of the system and not the system time, so this should not be an issue.
Apart from this, we generally follow up only on unmodified Klipper sources, as it makes no sense to hunt issues that potentially stem from third-party modifications.
Ok, i’ll revert any changes i did in this machine (basically install OS image again, reflash mcus, and install kipper and that normal stuff and will ser if the problem here is some inusual service or It is the mcu.
Anyways, is there other logs i could check to see if there is some service blocking the klippy log?
Thanks @Sineos !
