Kobra 2 Pro GPT damage
Printer Model:
MCU / Printerboard:
Hello everyone. I have rooted my Kobra 2 Pro, and the printer is working great. However, during boot-up, it seems that one of the partitions is showing as corrupted. I have already restored a backup I made earlier, but the issue persists. It appears to be booting from the backup partition. If that one also fails over time for whatever reason, I will have a problem.
How should I proceed to write the functioning partition onto the other one? I have also backed up the partition table, but every time I try to repair the table on my PC, it ends up completely corrupted afterward. I am, of course, doing this on my PC and not on the printer itself.
root@TinaLinux:/# [24]HELLO! BOOT0 is starting!
[26]BOOT0 commit : 4d16602
M/TC: OP-TEE version: 963b7e95 (gcc version 5.3.1 20160412 (Linaro GCC 5.3-2016.05)) #1 Wed Jul 28 12:51:52 UTC 2021 arm
U-Boot 2018.05 (Nov 17 2023 - 01:41:28 +0000) Allwinner Technology, Build: jenkins-PPL_104-PACKAGE-SDK-604
[00.276]CPU:   Allwinner Family
[00.279]Model: sun8iw20
[00.281]DRAM:  128 MiB
[00.284]Relocation Offset is: 04ec3000
[00.313]secure enable bit: 0
[00.315]CPU=1008 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz  MBus=300Mhz
[00.322]gic: sec monitor mode
[00.325]flash init start
[00.327]workmode = 0,storage type = 7
[00.330][mmc]: mmc driver ver uboot2018:2021-06-15 14:00:00
[00.335][mmc]: get sdc_type fail and use default host:tm1.
[00.341][mmc]: can't find node "mmc0",will add new node
[00.346][mmc]: fdt err returned <no error>
[00.350][mmc]: Using default timing para
[00.354][mmc]: SUNXI SDMMC Controller Version:0x50310
[00.379][mmc]: Best spd md: 2-HSDDR52/DDR50, freq: 2-50000000, Bus width: 4
[00.385]sunxi flash init ok
[00.388]line:703 init_clocks
[00.391]drv_disp_init
request pwm success, pwm6:pwm6:0x2000c00.
[00.404]drv_disp_init finish
[00.406]boot_gui_init:start
[00.409]set disp.dev2_output_type fail. using defval=0
[00.415]boot_gui_init:finish
GPT: last_usable_lba incorrect: ED7FFA > e90000
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: ***        Using Backup GPT ***
54 bytes read in 0 ms
[00.447]bmp_name=bootlogo.bmp size 522294
522294 bytes read in 12 ms (41.5 MiB/s)
[00.668]Loading Environment from SUNXI_FLASH... OK
[00.682]Item0 (Map) magic is bad
[00.684]the secure storage item0 copy0 magic is bad
[00.689]Item0 (Map) magic is bad
[00.692]the secure storage item0 copy1 magic is bad
[00.697]Item0 (Map) magic is bad
secure storage read widevine fail
[00.703]secure storage read widevine fail with:-1
secure storage read ec_key fail
[00.710]secure storage read ec_key fail with:-1
secure storage read ec_cert1 fail
[00.717]secure storage read ec_cert1 fail with:-1
secure storage read ec_cert2 fail
[00.725]secure storage read ec_cert2 fail with:-1
secure storage read ec_cert3 fail
[00.732]secure storage read ec_cert3 fail with:-1
secure storage read rsa_key fail
[00.739]secure storage read rsa_key fail with:-1
secure storage read rsa_cert1 fail
[00.747]secure storage read rsa_cert1 fail with:-1
secure storage read rsa_cert2 fail
[00.755]secure storage read rsa_cert2 fail with:-1
secure storage read rsa_cert3 fail
[00.762]secure storage read rsa_cert3 fail with:-1
[00.767]probe MP tools from boot
delay time 0
weak:otg_phy_config
[00.778]usb init ok
[00.796]LCD open finish
[01.281]usb overtime
[01.285]usb burn from boot
delay time 0
weak:otg_phy_config
[01.296]usb prepare ok
[02.099]overtime
[02.102]do_burn_from_boot usb : no usb exist
List file under ULI/factory
** Unrecognized filesystem type **
root_partition is rootfsA
set root to /dev/mmcblk0p5
[02.130]update part info
[02.146]update bootcmd
[02.175]change working_fdt 0x43e82e70 to 0x43e62e70
[02.196]update dts
Hit any key to stop autoboot:  0
dsp0:uart config fail
dsp0 version is e5844d06c622c0e98673085bfd7f1f7b8af283aa-dirty
DSP0 start ok, img length 220648, booting from 0x400660
[05.358]no vendor_boot partition is found
Android's image name: r528-k2
[05.371]Starting kernel ...
[05.373][mmc]: mmc exit start
[05.392][mmc]: mmc 0 exit ok
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.4.61-ab619 (devops@vhs-szl-0065) (arm-openwrt-linux-gnueabi-gcc.bin (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) 6.4.1, GNU ld (GNU Binutils) 2.27) #1 SMP PREEMPT Tue Nov 28 08:02:45 UTC 2023
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: sun8iw20
[    0.000000] printk: bootconsole [earlycon0] enabled
/dev/by-name/UDISK already format by ext4
/dev/by-name/rootfs_data already format by ext4
/dev/by-name/user already format by ext4
e2fsck 1.42.12 (29-Aug-2014)
/dev/by-name/rootfs_data: recovering journal
Setting free inodes count to 32791 (was 32794)
Setting free blocks count to 114700 (was 114872)
/dev/by-name/rootfs_data: clean, 105/32896 files, 16373/131073 blocks
Please press Enter to activate this console.
kmodloader done
Trying to connect to SWUpdate...
Hello @Prototyp !
When you want copy&paste code, please use Preformatted Text instead of
Blockquote
using some guide in the internet?
When you have a hardware issue with the K2Pro, you may consult Anycubic or a special K2Pro board. This is nothing that can be fixed/or has to do with Klipper.
Printer Model: Kobra 2 Pro
MCU / Printerboard: original?
Host / SBC: ?
Welcome Prototyp, could you give more information about your printer? I guess a klippy.log is not needed here.
The board is the original Trigorilla SPE V1.0.0. I got all the instructions from this forum. For example, here’s a link: Printer.cfg for Anycubic Kobra 2 Plus/Pro/Max - #122 by Catnippr
Unfortunately, the thread is closed.
