Laser Cutting causes “Missed scheduling of next hard pwm event” shutdown – possible bug?
Printer Model: Tronxy X5SA Pro
MCU / Printerboard: BigTreeTech Manta M8P v2.0 & Biqu Hermit Crab V2 CAN
Host / SBC: BigTreeTech CB1
klippy.log KlippyLog.zip (37.0 KB)
I’m running a laser module on a Hermit Crab toolhead plate for engraving and cutting. Engraving works flawlessly, but cutting consistently triggers the following shutdown:
MCU 'HermitCrab2' shutdown: Missed scheduling of next hard pwm event
This is generally indicative of an intermittent
communication failure between micro-controller and host.
Printer is shutdown
What I’ve observed
  • When cutting a rectangle, three sides complete without issues – the fourth side fails with this exact error.
  • Even a single straight cut reproduces the problem reliably:
    M106 S255
    G1 Y140 X0 F740
    M106 S0
    This shuts down after roughly 3 seconds – which matches my configured maximum_duration value exactly.
This leads me to believe that during a long, constant-power move, Klipper does not send periodic PWM updates to the MCU. Once maximum_duration expires without a new PWM event being scheduled, the MCU triggers the shutdown.
Regarding the maximum_duration parameter
I found a post on this forum from 2024 describing the same issue. The suggested solution was to remove the maximum_duration parameter, claiming it is deprecated.
However, this does not seem accurate:
  • The maximum_mcu_duration parameter in [output_pin] is deprecated (and has since been removed).
  • The maximum_duration parameter in [pwm_tool] is still documented in the Klipper configuration reference without any deprecation notice.
Simply removing this parameter is not a solution I’m comfortable with either, as it eliminates an important safety mechanism – especially for a laser module where an uncontrolled pin state is a serious fire hazard.
My question
Is this expected behavior, or is this a bug in how Klipper schedules PWM updates during long constant-power moves? It seems like Klipper should either periodically refresh the PWM state to satisfy maximum_duration, or handle the timeout differently when the PWM value hasn’t changed.
Any insights would be appreciated.
I guess there is a bug, from your example snippet:
In the batch mode
# rp2040 12MHz
queue_digital_out oid=0 clock=1370640371 on_ticks=6000
queue_digital_out oid=0 clock=1506871196 on_ticks=0
So, it schedules the first enable and then schedules the disable in 11.35s.
It seems to me that:
    def set_pwm(self, print_time, value):
        clock = self._mcu.print_time_to_clock(print_time)
        if self._invert:
            value = 1. - value
        v = int(max(0., min(1., value)) * self._pwm_max + 0.5)
        self._send_update(clock, v)
Schedules PWM in that way, and I guess, there are some checks missing.
Because it should probably be scheduled only up to 3s.
It may take some time.
Thanks for the report,
-Timofey
So, this is a duct tape, it should help.
But I’m not sure that this specific solution is correct.
Hope that helps,
-Timofey
It’s a bug. I applied @nefelim4ag’s change. Hopefully it fixes the issue.
Thanks for reporting.
