Missing scheduling of next hard pwm event
Printer Model: Self made cartesian CNC (I hope) plotter
MCU / Printerboard: SKR mini v.1.1
Host / SBC: cpRaspberry Pi (32 bit) & Linux on old laptop
klippy (1).zip (318.1 KB)
Hi, I have discovered strange behavior & stuck with laser configuration.
First I need to point out that laser head which I have to be disabled require 100% pwm.
However what I mean by strange is:
When I start gcode file w/o any M3/M4/M5 commands, and
then I issue M3/M4 S(whatever) using console in Moonraker/Mainsail all seems to work well;
but every time I run gcode whith those commands I get “Missing scheduling of next hard pwm event” (with laser turned on…)
Do you maybe know what could be a reason for it?
[edit]
Ok. I dig a little an found the nfoation that maximum_mcu_duration will be depreciated. I have commended it and now it works :wink:
However question remain why it works with manual gcode input but with mainsail running gcode raised an error.
This is the solution:
