Latest Build breaks MMU can on Happy
Printer Model: voron 2.4
MCU / Printerboard: mcu (stm32f446xx)
Version: v0.12.0-25-g99d7af87-dirty
Load: 0.06, Awake: 0.00, Freq: 180 MHz, Temp: 26°C
6
mcu EBBCan (stm32g0b1xx)
Load: 0.02, Awake: 0.00, Freq: 64 MHz, Temp: 69°C
2
mcu mmu (stm32g0b1xx)
2
mcu rpi (linux)
Load: 0.02, Awake: 0.00, Freq: 50 MHz,
2
Host (aarch64, 64bit)
Version: v0.12.0-19-g5bd32e29-dirty
OS: Debian GNU/Linux 11 (bullseye)
Distro: MainsailOS 1.2.1 (bullseye)
Load: 0.13, Mem: 417.7 MB / 827.0 MB, Temp: 35°C
eth0 (192.168.1.19) : Bandwidth: 4.8 kB/s , Received: 167.8 MB , Transmitted: 22.2 MB
can0 : Bandwidth: 0.6 kB/s , Received: 1.3 MB ,
klippy (2).log (6.5 MB)
config-20231207-223955.zip (24.5 KB)
I updated and got a weird error included in the image. Thought it was because klipper was on mismatched version, updated everything to same version. Still didn’t work. Would boot if i uncommented the happy hare stuff. I used git reset --hard 5bd32e2984b5d34ab54267aed3f078bd990d33b5 and everything started working all happy again :slight_smile:
I just pushed a fix for this… Just update Happy Hare and all is good again.
JFYI: Some changes were made in the Klipper toolhead init which I extend to control the MMU as a “second toolhead”. This could happen occasionally but if/when it does let me know and I can update…
So this isn’t a Klipper issue … it is a Happy Hare dependency issue.
Happy Hare upgrade info:
If running version v2.2 or higher, a simple moonraker update and klipper restart is enough.
If running v2.0 - v2.1, you will also need to re-run:
cd Happy-Hare
./install.sh
If running the much older “ERCF-Software-v3” code, then consult instruction in the README - you have more to do.
