Printer Model: Ender 3
MCU / Printerboard: Bigtree SKR 3 / Bigtree PAD7
logs-20231019-140932.zip (10.8 KB)
I have managed to get the standard screen that comes with a Ender 3 working and displaying and the navigation works, the only annoying issue is whenever you restart klipper the screen goes to the first submenu and I have to press the button to get to the home screen that displays all the stats. Hoping there is a way to fix this?
Sineos
October 19, 2023, 6:13pm
2
I’m not a good reference for display stuff, since I do not use them.
You might refer to [menu_root]
Theoretically, it should also be possible with something like
[delayed_gcode INITIAL_MENU]
initial_duration: 0.001
{% set level = "__main" %}
SET_DISPLAY_GROUP GROUP={level}
For the menu levels, refer to https://github.com/Klipper3d/klipper/blob/master/klippy/extras/display/menu.cfg
Thanks for the suggestion, unfortuneately this produces an error:
20:28:57 Unknown display_data group ‘__main’
But you get the idea, right? Adjust as necessary based on what your menu structure actually is.
Sineos
October 20, 2023, 6:46pm
5
Sorry, I guess this was not entirely correct. You need to define your own group or use one of the default groups as defined here: https://github.com/Klipper3d/klipper/blob/master/klippy/extras/display/display.cfg
So either [menu_root] or display_data should do what you want. Also ref to display_data
You will need to experiment or find someone more knowledgeable than myself WRT displays.
