Ender 3 Pro LCD screen not responding
Printer Model: Ender 3 Pro
MCU / Printerboard: SKR mini E3 V3
Host / SBC: Raspberry pi 4b/mainsail
klippy.log (235.3 KB)
Hello, my ender 3 pro’s LCD screen does not seem to turn on at all, and if i connect it to EXP1, it creates a really loud sound and the entire screen lights up. I triple-checked the printer.cfg (
printer.cfg (2.6 KB)
) but it has everything required for the lcd to work. Does anyone have any suggestions?
If it’s the standard Ender 3 display then did you use the modified cable for the SKR board?
Stupid question, what is the modified cable?
What would be the modified cable? The skr board supports the same cable. Thanks
You should check that the SKR board has the same pin layout as the Creality boards. Beeing a direct replacement it should, but better check.
When I used the stock Ender display I had:
[display]
lcd_type: st7920
cs_pin: EXP1_7
sclk_pin: EXP1_6
sid_pin: EXP1_8
encoder_pins: ^EXP1_5, ^EXP1_3
click_pin: ^!EXP1_2
With the definitions from BIGTREETECH-SKR-mini-E3/firmware/V3.0/Klipper/SKR-mini-E3-V3.0-klipper.cfg at master · bigtreetech/BIGTREETECH-SKR-mini-E3 · GitHub
[board_pins]
aliases:
    # EXP1 header
    EXP1_1=PB5,  EXP1_3=PA9,   EXP1_5=PA10, EXP1_7=PB8, EXP1_9=<GND>,
    EXP1_2=PA15, EXP1_4=<RST>, EXP1_6=PB9,  EXP1_8=PD6, EXP1_10=<5V>
it should work.
That if the cable is correct.
