Started algorithm testing on the actual printer. Doing batches of 50 probes at 1, 2, 5, and 10mm/s. Wanted to re-create the Euclid probe accuracy plots and got this…
I have no explanation for that sawtooth pattern! It was in the data before I started changing code and after. Its less pronounced at lower speeds, but still there.
Maybe:
- Some sort of issue with the tool changer mechanism? Like it gets pushed and then slips back?
- Timing issue?
- MCU clock drift?
