Looking for help setting up with Ender 3 pro 1.1.3 board
Printer Model: Ender 3 Pro
MCU / Printerboard: v1.1.3
klippy (3).log (211.3 KB)
It is possible I am just not sure what config I am supposed to be using. The ender 3 pro example config was talking about the 4.4.2 boards klipper/config/printer-creality-ender3pro-2020.cfg at master · Klipper3d/klipper · GitHub that I initially was trying to use.
I am getting the following error in the mailsail UI.
Pin ‘PB12’ is not a valid pin name on mcu ‘mcu’
Any chance of a nudge in the right direction? I did finally get Klipper installed on the printer, after I realized I had an older board than all the tutorials assumed.
If there is more info I need to provide, please let me know. I am sure my config is just based on the wrong info, but am not sure what I SHOULD use for a 1.1.3 board
I am so sorry, please disregard this. I loaded the configuration here https://github.com/Klipper3d/klipper/blob/master/config/printer-creality-ender3-2018.cfg
and connection is working fine. I have been looking into this for hours, and just saw this configuration referenced melzi boards…
