Mainsnail / Pi Network Problem
Printer Model: Cr10 Smart
MCU / Printerboard:
Hi, today i tried to Setup my Raspberry Pi 3 for my Cr10 Smart. I flashed the SD Card with Piimager (Mainsnail).
After booting up the Pi, i can connect and send follows through SSH.
So far so good.
Bute when it comes to connect to „Printername“.local, i can get no connection.
I searched for hours, to find somebody with the same Problem.
The Pi has a stable Wifi Connection, i even tried Lan.
It seems to be an Windows Issue, because i can Acess to Klipper via Iphone in the Network.
Maybe someone had the same experience and knows an Solution.
Thanks
The pintername.local is referring to the hostname of your operating system.
Refer to Manual setup - Mainsail for some pointers
