Printer Model: Voron 2.4 R2
MCU / Printerboard: Octopus
Host / SBC: Raspberry PI
klippy.log: Attached
klippy (8).zip (381.1 KB)
I’ve been using this printer for over a year and it’s been doing fine printing PETG without the top and sidepanels.
I need to print some ASA projects so I installed the side panels, doors, top and a pair of bed fans. I added Andrew Ellis bedfans.cfg just to get the be fans working. Ultimately I’d like to control the bedfans with the Chamber thermistor.
Upon trying to print a small project in ASA I received the following error;
Malformed command ‘TEMPERATURE_WAIT SENSOR = temperature_sensor chamber MINIMUM=40’
Searching the printer.cfg, I found this line of code;
TEMPERATURE_WAIT SENSOR = temperature_sensor chamber MINIMUM={target_chamber} # Waits for chamber to reach desired temp
I had thought that the slicer had chamber temps set to 0 for ASA so I put in appropriate values but still got the same error. A few line prior to this the target_chamber value does get set to 40.
I appreciate any help. I’d sure like to be able print ASA and nylon.
