After starting a print MCU will lose connection to the SBC and the print stops. I’m not super familiar with klippy logs, but I don’t see any errors in mine. It happens consistently with every long print (I’ve been running tests without filament) usually after more than 20 minutes but always before 1 hour.
Things I’ve tried;
Flashing new klipper installs
Flashing new mainboard firmware
Different cables between MCU and SBC
Swapping MCU, swapping SBC
Bypassing ender 6 daughter board
Printing without motors connected (in case it was some feedback from them)
Directly powering SBC from the powersupply
Different power outlets
Different power supply cable
Running without heated bed, to reduce power load
Direct cooling of boards with desk fan
I’m truly at a loss here, the only thing I can think of is that my power supply is bad? but I don’t know a good way of testing that other than the magic of buying 2 of them… (at this point I’ll have almost enough test parts to build a 2nd printer).
Huge thanks if any of you more experienced folks can come up with some kind of solution.
Welp, I tried swapping the pi to a different power supply. Ran with the MCU on one supply and Pi on the other. Then when that crashed swapped both to the 2nd supply. Still crashed. I’m running the Pi off a DC converter at ~5.08V.
In the past I tried running it from a usb power supply and that ran into similar issues.
News, I think it is solved now. Last time I put things together I figured I’d try with as few things attached as possible. I think there is a klipperscreen interaction with the panel that came with the printer that was crashing things. I ran through 3 prints of 2+hours without issue this weekend, so fingers crossed…
Thanks Cardoc for being there for me <3
