Connection loss and lost
Printer Model: ender 3 s1 plus
MCU / Printerboard: sonic bad / V2.4.S1 Silent MotherBoard
1- klippy.log (506.1 KB)
2- klippy (1).log (77.2 KB)
Hi
I have a one problem and 2 logs for the same problems in my printer It appears to me Klipper state: Disconnect and
Klipper reports: SHUTDOWN
Lost communication with MCU ‘mcu’
Printer is shutdown
Sometimes it appears to me after 4 hours, 8 hours, 12 hours or more.
I changed the cable connected to the printer and mcu serial in ( by-id to by-path ) Nothing has changed.
See line 601 file 1.
See Timeout with MCU / Lost communication with MCU
I have reinstalled the system and installed all the drivers but the problem still exists. I added new log files
klippy.log (146.6 KB)
moonraker.log (21.6 KB)
dmesg.txt (32.0 KB)
Did you try any of the suggestions in the link @Sineos posted?
Yes I tested the internal power supply of the printer and the power of the sonic pad is all stable and full and I do not have a camera or other device connected to the sonic pad
It suddenly shuts down, whether it is idle or printing.
is there anything new?
On the
you may read here:
