Printer Model: Ender 5 Plus
MCU / Printerboard: BTT SKR Mini E3 V3.0
klippy.log (3.1 MB)
45 minutes into a print, just got that error, first time doing a long print with klipper.
Here was the hardware status of the last hour or so.
All seems good.
Sineos
2
The graphs you are showing look suspicously like Proxmox. If so, nothing is good: Running Klipper in a Virtual Machine (VM)
Yeah, it is in proxmox. Basically I only had one available machine so I decided to slap that in with USB passthrough, I got those errors.
How I solved it, using Q66’s solution from the klipper discord:
- I had a old RPI 2B. Install Ser2Net on it, forwarded the serial connection over TCP.
- On the klipper Host, installed Socat to connect to the TCP Socket and output the serial to /dev/pts/2
- Change printer.cfg to /dev/pts/2 for MCU.
This basically tunnels in the serial via IP.
It’s been working wonderfully since then. Klippy logs shows that MCU_TASK_AVG and mcu_task_stddev have both dropped by about 75%.
