Mcu 'rpi' unable to connect
Printer Model:Neptune 4 Pro with OpenNeptune
klippy.log (1.2 MB)
MCU / Printerboard:
Hey guys.2 days ago i shutdown my printer properly and today when i turned it on it felt weird then the “mcu ‘rpi’: Unable to connect” error code popped up.Everything is up to date and i dont know what to do
This file
[mcu rpi]
serial = /tmp/klipper_host_mcu
is likely missing or corrupted. Details at the link below.
I didnt touch any mcu config yet.Its worked until 2 days ago.
My code looks like this:
[mcu rpi]
serial: /tmp/klipper_host_mcu
[adxl345]
cs_pin: rpi:None
spi_bus: spidev0.2
I dont know what happened with it
On a RPi the first suspect is the SD card. They do wear out.
In anu case Klipper has to read that file to enable the [mcu rpi]. You could comment out the lines and all the accelerometer references. Klipper should be happy but obviously the accelerometer will no longer work.
