mcu: Serial connection closed / Timeout on connect / Wait for identify_response
Background
The printer-board / MCU did not respond to the connection attempt of the Klipper Host until finally the serial connection timed out and was closed. Often, these 3 errors will go hand in hand in the klippy.log
Reasons
- Hardware issues between the board and the SBC, e.g. USB port, USB cable etc
- Wrong parameters during
make menuconfigwhen building the firmware for the board - Firmware not correctly flashed to the board
- Dead board
Potential solutions
- Follow the dmesg procedure to check if and how the board registers in the operating system
- Following symptoms in the dmesg output point to either a not correctly flashed board or some hardware issues
- It registers, but quickly gets disconnected again
- It registers, but around this process are some USB related errors in the dmesg log
- The dmesg output shows simply nothing, when the board is freshly connected
- Check and verify the parameters used during
make menuconfig - Repeat the flashing process and pay special attention to the instructions given on top of the example config files
- Use different SD cards (preferably below 8 GB) for the flashing process
- Make sure the board has proper contact to the SBC. Use a high quality USB cable
- Check with
ls /dev/serial/by-id/*for the presence of the board and compare the output to the settings[mcu]block - Read Issues flashing the printer board for more detailed information
