Mcu unable to connect, sv07
Printer Model: sovo sv07 plus
MCU / Printerboard: stm32
Host / SBC OS: Armbian 22.05.0-trunk Buster
klippy (16).log (1.6 MB)
I dont know whats happening, cant put mainsail working, already flashed mcu board several times, already upgraded klipper and happyHare,
Hi @David3d ,
From the log:
serialhdl.error: mcu 'mcu': Serial connection closed
This typically indicates that Klipper isn’t properly flashed to the mainboard.
when i do ls/dev/serial/by-id/* it shows the actual board
  1. I cannot comment on the settings or the needs for this printer, as it typically has an OEM-modified Klipper setup. Regarding “Disable SWD,” make sure that it is indeed a GD MCU; otherwise, it will not boot properly.
  2. I’m not fully convinced that using a self-compiled bleeding-edge Linux/kernel version is a good idea unless you can debug and solve issues arising from it. An eth0 error on the MOTD does not increase this confidence.
  3. Follow this link.
i didnt replace the name of the .bin file, that was the issue
