Hello. Sorry for the slow reply, I was away for the last week.
When I contacted Creality, they advised to try switching USB cables. Since I had switched the USB cable not long before getting this error, I switched back to the USB cable they had originally sent me, and tried it again. The print died in the exact same spot, 52 layers in out of 56, with the exact same error. At that point, I do have to assume there is some movement in the gcode that is causing the problem but I lack the skills to identify it. It seems to be happening right at the layer change to 52.
I’m going to post two snippets of gcode, right around the layer change to 51 (which had a color change, and which went fine) for comparison, and then right around the change to layer 52 which is where it’s breaking down, possibly on the wipe movement? I’m hoping someone around here can possibly see if there’s something obviously and egregiously wrong here, because comparing the two snippets, I’m not spotting it…
Layer 51 - color change. This worked fine, like the previous 50 layers. Providing only for comparison.
G1 E-.8 F1800
G1 X46.483 Y128.387 F9000
G1 E.8 F1800
G1 F2400
G1 X43.993 Y130.876 E.0671
G1 X43.811 Y130.935 E.00365
G1 X43.228 Y131.346 E.0136
G1 X43.11 Y131.53 E.00415
G1 X43.005 Y131.793 E.00541
G1 X43 Y131.87 E.00146
G1 X41.747 Y133.123 E.03378
G1 X42.054 Y132.389 E.01517
G1 X46.273 Y128.17 E.1137
G1 X46.168 Y127.849 E.00645
G1 X42.501 Y131.516 E.09885
G1 X42.754 Y131.041 E.01026
G1 X43.074 Y130.517 E.01171
G1 X46.064 Y127.527 E.08059
G1 X45.959 Y127.205 E.00645
G1 X43.829 Y129.334 E.0574
G1 X44.783 Y127.954 E.03198
G1 X45.96 Y126.777 E.03172
; stop printing object Articulated_Monarch_3_Layers.stl id:0 copy 0
;LAYER_CHANGE
;Z:8.2
;HEIGHT:0.16
;BEFORE_LAYER_CHANGE
G92 E0
;8.2
;WIPE_START
G1 F7200
G1 X44.783 Y127.954 E-.39532
G1 X43.91 Y129.217 E-.36468
;WIPE_END
G1 E-.04 F1800
G1 Z8.2 F9000
;AFTER_LAYER_CHANGE
;8.2
;COLOR_CHANGE,T0,#FFFFFF
M600
; printing object Articulated_Monarch_3_Layers.stl id:0 copy 0
G1 E-.8 F1800
G1 X47.135 Y128.182 F9000
G1 X48.932 Y127.605
G1 X50.972 Y126.951
G1 X76.092 Y118.878
G1 X75.972 Y118.926
G1 E.8 F1800
;TYPE:Perimeter
;WIDTH:0.329999
G1 F1500
G1 X73.261 Y119.036 E.05069
End Layer 51 snippet
Layer 52 - MCU stepper error happens around here
;WIDTH:0.340058
G1 F2400
G1 X158.448 Y137.256 E.00949
G1 X158.357 Y137.597 E.00682
G1 X157.826 Y137.065 E.01452
G1 X157.427 Y137.099 E.00773
G1 X158.266 Y137.938 E.02292
G1 X158.174 Y138.279 E.00682
G1 X157.026 Y137.13 E.03139
G1 X156.594 Y137.131 E.00833
G1 X158.083 Y138.62 E.04068
G1 X157.992 Y138.961 E.00682
G1 X156.163 Y137.132 E.04996
G1 X155.732 Y137.133 E.00833
G1 X157.9 Y139.302 E.05925
G1 X157.809 Y139.643 E.00682
G1 X155.3 Y137.134 E.06854
G1 X154.866 Y137.133 E.00838
G1 X157.718 Y139.984 E.0779
G1 X157.626 Y140.325 E.00682
G1 X154.455 Y137.154 E.08663
G1 X154.38 Y137.511 E.00704
G1 X157.166 Y140.297 E.07614
G1 X156.625 Y140.188 E.01068
G1 X154.304 Y137.867 E.06341
G1 X154.228 Y138.224 E.00704
G1 X156.083 Y140.079 E.05068
G1 X155.534 Y139.962 E.01085
G1 X154.152 Y138.58 E.03774
G1 X154.076 Y138.937 E.00704
G1 X154.971 Y139.832 E.02444
G1 X154.409 Y139.701 E.01115
G1 X153.888 Y139.181 E.01421
;LAYER_CHANGE
;Z:8.36
;HEIGHT:0.16
G92 E0
;8.36
;WIPE_START
G1 F7200
G1 X154.409 Y139.701 E-.1747
G1 X154.971 Y139.832 E-.13713
G1 X154.076 Y138.937 E-.3005
G1 X154.152 Y138.58 E-.08658
G1 X154.334 Y138.762 E-.0611
;WIPE_END
G1 E-.04 F1800
G1 Z8.36 F9000
;AFTER_LAYER_CHANGE
;8.36
G1 X153.333 Y138.509
G1 X151.502 Y138.045
G1 X145.511 Y136.529
G1 X143.675 Y136.064
G1 X138.184 Y134.674
G1 X136.44 Y134.233
G1 X134.538 Y133.751
G1 X117.445 Y129.424
G1 X115.115 Y127.635
G1 X111.53 Y122.902
G1 X111.196 Y122.279
G1 X110.705 Y122.213
G1 X109.65 Y122.253
G1 X109.646 Y122.254
G1 X109.351 Y122.308
G1 X109.163 Y122.454
