! MCU 'THR' shutdown: weight_error
Printer Model:qidi q2c
MCU / Printerboard:
Just replaced both fans and the print head (hotend and nozzle). First time failure had filament melted all over the print head, melting wires to the fans.
Not real smart at the 3d printing. we have several printers and this was our first major failure.
After replacing the fans and trying to print we get this error on every print.
We have the box and all those settings are the same as before the damage to wires.
don’t understand the weight_error cant find it any where that i have searched.
We have a qidi q2 that i replaced the print head (hotend and nozzle) and one fan and its printing normal
15:47:48 // MCU ‘THR’ shutdown: weight_error
// CS传感器有问题,请检查一下接线!
// Once the underlying issue is corrected, use the
// “FIRMWARE_RESTART” command to reset the firmware, reload the
// config, and restart the host software.
// Printer is shutdown
15:47:48 !! MCU ‘THR’ shutdown: weight_error
Any help or advice would be appreciated.
Bill
Please review the header for a new post.
No way we can help without a klippy.log
Note: It is likely your error is originating with qidi specific (not open source) mods to klipper. You should attempt to contact qidi support and/or a qidi user forum.
