MCU unable to connect on mks v1.4
Printer Model:Leapfrog Creatr
MCU / Printerboard:MKS GEN V1.4
Host / SBC Raspberry pi 3B+
klippy.log (112.9 KB)
mcu ‘mcu’: Unable to connect
Error configuring printer
I’ve re-installed klipper quite a few times , and have also checked mcu serial , multiple times , and for info
klipper is active
”mcu is not connected “ this is the only issue that I’m having right now , also want to know does this board support klipper at first place , because i know these 2560 boards are supported , and their cfg files are available for reference
Since , I’m unable to find a proper solution for this issue , I’m trying to find an answer here , and I’m in a very urgent need to complete this klipper work and move ahead , so any response regarding the same is much appreciated
Hello @Sarvesh0205 !
How did you flash that board?
via make menuconfig
then
MCU Architecture: Atmega AVR
Processor Model: ATmega2560
Communication: UART 1
BAUD RATE : 250000
Flashed using this : make flash FLASH_DEVICE=/dev/serial/by-id/ usbFTDI_FT232R_USB_UART_AD0JMQNT-if00-port0
this is the serial aswell : /dev/serial/by-id/ usbFTDI_FT232R_USB_UART_AD0JMQNT-if00-port0
if you want I can drop in printer.cfg aswell ,
hopefully we can fix this issue
thanks for the quick reply mate
Thanks for showing your concern and providing a response
the issue is solved , I flashed through KIAUH
and its showing my mcu and my printer is up and running
