Hello. I’m new to the forum and I apologize for my bad English. I’m asking for help configuring the ir sensor on the extruder. I’m using an mmu2 clone with a skr mini e3 v3. The problem occurs when I finish printing and it starts the m702 code to unload the filament. The first stage is ramming in the extruder and then the filament should be pulled into the mmu2. But since the ir sensor is higher than the gears, it immediately pauses. Since I’m worse at programming, I’m asking for help editing mmu2.cpg to change that the sensor is 18mm away from the drive. Thank you for your help.
Hello @malovrhm !
When you opened this thread you have been asked for the klippy.log (You deleted that text right away)
Please attach the klippy.log to your next post
