Move exceeds maximum extrusion (0.717mm^2 vs 0.640mm^2)
Printer Model: Custome
MCU / Printerboard: SkR v2.0[Part 0308A1.gcode|attachment]
(upload://lfGbNodcj8VBdPFlHRkCPLmMjjn.gcode) (7.7 MB)
Without any additional information under what circumstances and conditions this happens, it is not possible to make any attempt for a solution.
And the upload of the gcode file did not work.
Just zip it and upload both in your next post.
If this is an error that occurs when the extruder is operated, please raise the value higher if the extruder item has “max_extrude_cross_section:” . If you don’t have any items, add them and add enough value to drive them
The default value is calculated as nozzle ^2*4, so 0.4mm nozzle will be applied as 0.64
If you have a standard printer with a standard 0.4 nozzle, then this advice is simply wrong. Under normal operating condition this error does not happen. If it happens then something else is wrong.
@anurag30atulya please follow @EddyMI3D’s advice and post your log. Otherwise check [H] Move exceeds maximum extrusion - #2 by Sineos for more details.
