Move exceeds maximum extrusion (AA mm^2 vs BB mm^2)
Background
Klipper has a safety mechanism that checks if a single move extrudes an unhealthy amount of filament or if the extrusion of multiple moves add up to such an amount.
This limit is calculated according to following formula:
Maximum Extrusion = 4.0 x Nozzle_Diameter^2 = 4.0 x 0.4^2 = 0.640 mm²
For the standard 0.4 mm nozzle the default values calculates to:
Maximum Extrusion = 4.0 x 0.4^2 = 0.640 mm²
Reasons
- Misplaced
M83(Relative Extrusion). This by far the most common reason - Too extreme prime lines, e.g. high
Evalues across a short movement - Too extreme purge settings during filament change
- Weird Slicer settings affecting the extrusion or flow rate
- Mismatching extrusion modes (absolute / relative) between slicer and Klipper
- Changed nozzle for a higher diameter but not adapting the configuration
Potential solutions
- Usually working with
M82(Absolute Extrusion) is preferred- Check start-gcode, start macro etc. for
M83commands and remove them - Check slicer setting and verify that the slicer is set to absolute extrusion
- Check prime line / purge gcode if a high volume is extruded over a short distance
- Check for slicer settings that may affect the extrusion logic
- Check the
printer.cfgif thenozzle_diametersetting is correct - Cranking up the
max_extrude_cross_sectionsetting in[extruder]section is not a solution. The underlying problem may cause issues later
Additional Background
If there is interest, how for example a prime line is calculated in the context of this error message, this is the math:
Input Parameters
- Nozzle Diameter: 0.4 mm
- Filament Diameter: 1.75 mm
- Extrusion Width: 0.48 mm
- Layer Height: 0.2 mm
- Print Speed: 80 mm/s
- Extruded Length: 15 mm
- Movement Length: 30 mm
Calculation
max_extrude_cross_section [mm²] = 4.0 x Nozzle_Diameter^2 = 4.0 x 0.4^2 = 0.640 mm²
Extruded_Volume [mm³] = Extruded_Length [mm] x (Filament_Diameter [mm] / 2)^2 x Pi = 15 mm x (1.75 mm / 2)^2 x 3.14 = 36.1 mm³
Actual_Extruded_Cross_Section [mm²] = Extruded_Volume [mm³] / Movement_Length [mm] = 36.1 mm³ / 30 mm = 1.2 mm²
- If one single gcode command (e.g. starting at X=0 / Y=0:
G1 X0 Y30.0 Z0.3 F1500.0 E15), would request a movement of 30 mm while trying to extrude 15 mm filament (gcode:E15) it would result in aActual_Extruded_Cross_Sectionof 1.2 mm² - Klipper would react with an error message saying
Move exceeds maximum extrusion (1.2mm^2 vs 0.640mm^2) - To solve the issue, either the
Movement_Lengthneeds to be increased by a factor of 1.875 to minimum 56,25 mm or theExtruded_Lengthdecreased by the same factor toE8
